No power to the head unit?
I had to hardwire my head unit and i had it working perfectly. However i went to finalize the install and slide it in flush with the dash and then it shut off and no power. Any suggestions? I’m thinking it could be a fuse but i don’t know where the fuse is to replace it.
there’s a fuse on the headunit itself or the fuse in your fusebox.
if you twisted the wires one of them may have came apart
i have checked all the wiring… but which fuse in the fusebox would i have to replace?
There are two fuses, fuse 14 - 15A, [hot at all times] and fuse 22 - 10A, [hot in acc. and run] both are in the under dash fuse box.94
thanks. i will try replacing them tomorow
