Symptoms:
Car would just not start on random days, usually very cold days. When I put the key in, the cluster lights and everything would be very dim as if battery was completely drained. So i replaced my compact Odyssey Battery with a regular sized BRAND NEW EXCIDE. Problem solved. Did not have a problem starting it at all.
Car sat for 3 days due to a snow storm. I tried to start it, and nothing. DOESNT CRANK, starter does not click at all. THE CAR SHOWS NO POWER WHAT SO EVER WITH THE KEY IN ACC.
I CHECKED THE BATTERY WITH A METER, FULLY CHARGED.
I had a spare §§§§§ that I know is good for a fact. Swapped it in just to make sure it wasnt the Ignitor coil. STILL NO POWER WHAT SO EVER.
I assumed it was the Main Relay which is known to go bad on these cars. I resoldered it and BAM the car started! I shut it off and tried to start it one more time to make sure that was the problem solver…ONCE AGAIN NO POWER RUNNING THRU THE CAR AT ALL.
I picked up a BRAND NEW MAIN RELAY, installed it. BAM STARTED RIGHT UP! SHUT IT OFF…tried to start it again…SAME THING! NO POWER ONCE AGAIN!
What could be the culprit of this? Could my car somehow be blowing these main relays instantly???
IM REALLY STUMPED! PLEASE ANY PUT FROM YOU ELECTRICAL GURUS WOULD HELP!
Just to recap…FAIRLY NEW ALT. NEW Distributor. NEW BATTERY. NEW MAIN RELAY…but still NO POWER…can’t turn the lights on, put windows down, radio…NOTHING
