I’d like to simply just have an intake, 4-2-1 header, resonated hi flow cat, and catback exhaust.
The intake and exhaust will be PasswordJDM Power Chamber, and Greddy SP2 exhaust.
I’d like a recommendation for the header and resonated hi flow cat.
I want something relatively quiet and no rasp. So this means I don’t want a ricey, loud, tin can, raspy setup I typically hear on civics. i want this to be a clean smooth sound. thank you
you’re gonna really get that real raspy sound with the exhaust that you choose, and you already picked yours in your case.
Have you youtubed what that exhaust sounds like?
stock ls engine?
the header will open it up a bit, but how much are you looking to spend?
yeah like josh said its all in how much you plan on spending… ive heard mixed things about the pwjdm intakes none of which were any good… if you can get ahold of a rsr exmag exhaust that’d be the best… the reason civics sound like fart cans is because they have 2" piping running to a 3" exhaust most of the time… i dont believe a header affects the sound as much as what exhaust you run and the size of your exhaust piping and either or not you run no cat or a high flow cat… for the most part intakes are just intakes… you can custom build your own intake with vibrant if thats an option…
Yeah I agree with DAproject. The header doesn’t affect the sound. I have switched mine out like five times trying to get the best air flow and they never made a difference on how the car sounded. The exhaust and cat was the only thing that affected the noise. I think you should go with the RS*R bolt up exhaust system they make for DA’s.
i youtube’d a bunch of videos of the RSR ExMag and Greddy SP2 exhaust and from what I can tell, correct me if I’m wrong since you really can’t get a feel of the exhaust note in videos, the SP2 is slightly louder than the ExMag and has a deeper tone which I prefer. I didn’t hear any rasp, that I can recall, from IMCNBLU’s videos and he has the Greddy with some other boltons and a B18C. It’s hard for me to decide cause there’s no DA meets around NYC.
i believe the sp2 has a 2.36" piping so it should be okay? i’ll make sure to keep the piping consistent.
price for header and cat should be below $600-700. i don’t need a rare, full race 4-1 header.
