no spark no fuel please help
okay so i have a 1991 integra ls slammed. pullin out of my driveway randomly shutoff i know i have a full tank of gas, i checked to see if i was getting fuel and spark and i wasnt. so would there be a fuel reset swtich? fuel fuse, fuel relay? i need some help i gotta get this thing running again its my only transportation id really appreciate it, thanks. i checked all my fues by the kick panel and the engine bay and they are all good so i didnt think it would be a fuse
check your MFR
91 integra ls mfr?
wheres the mfr on a 91 integra ls? im not getting any fuel nore spark it randomly died and now im not getting any fuel and no fire. i replaced the ecu 3 times the main relay 4 times. so all i want to know is what the possibalitys is why it died and the fuel and no spark happend at the same time and what i need to get to fix it.
headaches of no fuel and spark help please
im not getting any fuel nore spark it randomly died and now im not getting any fuel and no fire. i replaced the ecu 3 times the main relay 4 times. so all i want to know is what the possibalitys is why it died and the fuel and no spark happend at the same time and what i need to get to fix it. if it was the main relay the starter woudnt engage, so dont say its the main relay. ik my fuel pump is good i just changed it. i was just randomly go out my driveway and it just shut off and all it does it turn over. no fuel no spark. so i was thinkin crank sensor but ive looked it up and called autozone and they said 1991 integra ls obdo doesnt have a crank sensor. so what would cause it to look spark and fuel at the same time!!??
First of all. How are you checking to see that your not getting fuel or spark?
Second if your main relay was bad your stRted will still crank. So your main realy is still a possible cause.
Third. All of our integras have a crank sensor. It’s located inside the distributer so who ever told you yours didn’t is wrong.
I’m assuming you ready check all of the fuses.
Can you hear the fuel pump for a few second once you turn on the ignition? If not, then let’s start there. Get a car heater cleaner or startng fluid. Spray some in the throttle body while Holding it WOT. Go and try to start the car. If it start and shuts down then most likely you have spark. Repeat the same step and have someone turn the car on. Try to spray fluid into the throttle body a few sprays at a time to keep the engine running. If it stays up the. Your problem is the spark. Check your distributor.
If you want to check if you have spark, simply pull one of the spark plug cables and stick a Phillips screw driver into the cable. Then, get the screw driver metal part close to any bolt that’s grounded. Have so done crac the motor and see if your getting spark.
no fuel and spark is almost certainly the crank sensor. the pump will prime, but won’t continue to run without crank signal. pump also won’t run while cranking with no ckp
