noise in my tranny
ok here the thing, I just fished swaping a b18c1 into my 92 integra; i put an LS cable tranny on, the engine starts and sounds fine but when i go to put it in any gear it wont move and makes some weird noise. It sounds like the noise is coming from the tranny area.
I’m not sure what could be the problem my guess is something with the clutch. Can any one please help me or if anyone has had a similar problem?
What year is your tranny, if it’s a 90-91 and you used a 92-93 clutch disc that could be one problem. Another is maybe your clutch cable needs to be adjsuted.
that’s what came to mind, i put the car on jack stands and tried seeing if the wheels moved like that and they didnt but when i’m letting my clutch pedal out it doesnt feel as if its grabing. the noise wasnt as bad, my brother thinks it could possibly be the spring or fork inside the tranny not installed right or something like that? but i’ll try changing the cable just incase i have one laying around witch looks in better condition then the one on the car. Thanks!!!
could be the throw-out bearing. did you put in a new throw-out bearing when you replaced the clutch? did you even put in a new clutch?? make sure the tranny bolts are nice and tight…sometimes when you tighten them down the others becomes loose, causing the tranny to not sit flush with the surface of the block. just an idea, because i remember when my tranny was not shifting so smoothe…i noticed a tranny bolt not completely tightened down, once i did tightened it down it started shifting fine. anyways…let us know if you found out the problem.
AAhhh got the car going now. I changed the clutch not exactly sure if that was the problem cause both clutches looked alike. but the good thing is its going now… THANKS for help!! now I just got to tune it right.
do N E one know what the fuel pressure should be set at?
Ok now that the car has started and everything we are trying to set everything to were the car is running normal but on acceleration the car stalls some what, or if i let of the gas it seem to pull bad my friend thinks its the throttle since i’ve changed the Intake mainfold but have the stock throttle body. does anyone know what this problem could be,
All I figured most my problems out now, the car is running good.
I just need to wire vtec, also my check engine light is I’m guessing it could be cause my vtec is not wired? not exactly sure. Does anyone know what I need to check the codes ecu is throwing?
Thanks
