Car is now being fully parted out. Let me know what parts you need if not listed and i’ll get you a price. I will be
updating this thread with pictures as I pull parts off the car.
Shell – $750
Painted Lexus Platinum Silver - Clean title; no accidents or rust -
Custom external mount Endyn Bosch fuel pump
Earls -6 feed line from pump to rail
Lightspeed stainless brake lines
Axxis Metalmaster pads
Prothane complete urethane bushing set
OEM 92-93 front & rear bumpers
JDM front bumper support
14" LS Snowflakes with good tires
Clifford IQ-800 alarm with custom locks
Engine -
AEM Cam Gears (pair) - $SOLD
Fluidyne 92-95 Civic radiator with Permacool slim fan - $SOLD
ARP B18C/LS-VTEC 208-4303 head studs, torqued down only once - $SOLD
Type-R throttle body - $SOLD
Spoon Radiator Cap - $SOLD
Type-R valve cover uncut, includes valve cover grommets - $SOLD
GSR power steering bracket, cut in half for clearance on my Full-Race manifold; works great - $SOLD
Short Block - $650
B18A LS block 118k miles, approx. 38k on rebuild. My car hasn’t been driven for the last 4 years besides the occasional start for a few minutes to keep the fluids circulating or to move the car out of the garage, so I am selling everything for the price of the rods themselves. Last compression test was 175-180 across the board.
JE SRP 9.0:1 cr .010 over pistons
Crower steel billet pro rods
Micropolished and balanced crank
Z10 engineering main block girdle
Prodrive billet oil pump gear
Nuformz block guard
Type R Oil Pump
Type R Water Pump
98 GSR Oil Pan
98 GSR oil pickup
98 GSR windage tray
98 GSR water pipe
98 GSR oil cooler
Mugen thermostat
2000 Type-R cylinder head (tapped for LS-VTEC but plug can be removed) - $375
Comes with VTEC solenoid, rockers, cam caps, Endyn Titanium retainers/dual valve springs, (B16A2 cams additional $25)
Type-R intake manifold - $175
Comes with IACV, intake air temp sensor, 2 extra vacuum ports
Greddy oil filter sandwich adapter - $35
B16A2 cams - $50 (or $25 with purchase of head)
Earls -6 line used for oil feed on my LS-VTEC setup - $20
email qwkteg125 at yahoo dot com for parts/picture requests
