Well like the title says. . .
A LITTLE back ground:
The car ran fine except every now and then the TEMP gauge would go up.
I would turn on the heater and full blast and no go. Temp would not go down.
If I was crusin and downshifted to make the motor run faster it WOULDNT make the temp go down,
So after a closer inspection I noticed that my compression leaked into the COOLANT system.
So I decided to tackle a head gasket job, and did everythin like it should be done. FYI this wasnt my first HEAD gasket NOT only that I have an OEM integra book covering the whole shebang on how to do the head gasket . .
so got everythin back together, yet timing was off.
RE DID timing and it was good, motor sounded better.
It has fuel
it has spark
BUt doesnt stay on once you get it to start, UNLESS you hold the gas PAST 1k and IF you go past 4600 the RPMs go wack.
So got A NEW distibutor and was slapped on also another ECU was swapped out from a good runnin DA and it started fine but still no go
KEEP IN MIND MOTOR RAN FINE EXCEPT FOR COOLANT ISSUE, NO ELECTRICAL OR COMPONENTS ISSUES OR ANYTHIN ELSE FYI
But after every time you reset the ECU it staRTS up with no ISSUE
EVEN slapped on a PK2 PRELUDE ecu and started up on first try but died after 2 minutes too being wrong ECU IMO,
so IM lost guys I really dont want to part away with the car, shes been the longest car I have owned
I know its something mechanical
BUt funds and TIME and short to figuere her out
HENCE she sat for 4 yrs till she ran again and she DID held up good with tha abuse too.
Im just lost and dont know wat else to do.
I DONT WANT to sent her to the CRUSHERS or SELL her off, cause in HOUSTON you dont see many 4 door DB1s specially factory 5 speed ones too
SO I finally come onto here for aid.
This site has always been good to me foe info so hope some good PPl chime in with good info.
Cause I miss MY BBY!!!
