Now The Fun Part!
I Just Got Back Into A DA 2 Weeks Ago, & Its Gonna Take A Minute To Get It Back Up To PAR
  1. So On Sunday The Timing Belt Snaped, In The Process Of Doing It But The Damn Crank Pulley Wont Come Off :bang: ( Breaker Bar, Air Tools Atleast 275psi) Last Resort Torch The Bolt Then Hit It With Air Gun
    -Not To Mention That I WOnt Know If The Valves Are Bent Until I Put The Belt Back ON To Do A Leak Test, But It Wus In Need Of An Adjustment To Begin WIth.
  2. Needs Mounts All Around ESPECIALLY TRANNY MNT To Be Replaced. ( Shakes Traveling @ High Speeds )
I Go Back To School Next Week & Dnt Know When ILL Be Able To Finish It :frowning:
http://forums.g2ic.com/announcement.php?f=29&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
