Have tested everything i can think of and still have no pulse from injectors. All injectors have 12v and continuity from injector clips to ecu. Have tried using several ecus and still the same. What else could it be
what injectors are you using? 0 or 1?
because obd1/2 injectors have a built in resistor in them.
obd0 injectors have a separate resistor box (that grey box with the green connector by your brake booster)
you cant use obd1 injectors with the resistor box.
you can either run obd0 injectors with that box
or
if you wanna stay with the obd1 you have to splice all those wires from the green connector and wrap it up.
I tried that and it didnt work. The injectors i am using are obd-1 b series. Also number one injector has power when ignition in on the on position. Loses powere when cranking
Any one? I have had this car for four years and cant get it going HELP!
