i searched around and i found that i can use an obd0 b18 in my 92 teg if use these obd1 parts:
-distributor
-alt
-engine harness
however i can find anything that says if i can use the obd0 injectors, i assume the clips are dif and ill need obd1 inj but i wanted to confirm before i start buying shit i dont need, also can i use the obd0 intake mani or will i need the obd1 ?
You can use either/or manifold as far as I know… But yes the injector clips are different. It would be easier ti keep the obd1 injectors.
thats what i figured
anything else im forgetting? what about the ac comp or fans?
Compressor and fans wont change anything.
how about the starter, can i use the one from a obd0 teg
LOL, aren’t you the guy that’s soliciting online tunes (don’t even get me started on that shit) here?? This is the kinda knowledge that is requisite…
whats your beef with online tuners ?
