ok so i have been searching around alot for some info on this but i can’t seem to find anything.
i have an obd1 motor with an obd0 intake manifold and obd0 injectors/fuel rail but the rest is obd1 ( §§§§§, o2 sensory etc ) the car was originally obd0 but it has an obd1 body harness and an obd1 engine harness. well my problem is that i can’t seem to figure out where all the coolant and vacuum lines by the intake manifold go, does anybody have a picture? the ones im talking about in particular is the coolant like that goes through the bottom of the intake manifold, the vacuum lines for the map senor, evap, fuel pressure regulator control solenoid valve, and the coolant lines under the intake manifold. it also seems as though the obd0 intake manifold has more sensors on the front than the obd1 did, is this true? do i need them? if not how do i block them off?
if somebody has a pic of on obd0 intake manifold the shows the coolant and vacuum lines it would be greatly appreciated if you would post it up for me.
