Alight so I have some questions regarding about converting to OBD1 or either keeping it OBD0 for the sake of time and money. This is a daily driver but I hope to take it to the track as well (some spirited intent).
My current setup: Recently swapped low comp B20B with I/H/E. 90 GS 4dr.
I am debating whether it is best for me to have my OBD0 ecu chipped with a good basemap and have it tuned with turboedit and on a dyno later…but it seems no one around tunes obd0…Or I can run obd1.
I’ve done some research on the OBD1 conversion following Colin’s advice. In order to reap the FULL benefit I would assume you’d need the following:
OBD1 ECU (chipped); ECU Conversion Harness; OBD1 Dist.; 4 wire O2; IF considering OBD1 injectors convert that and eliminate Resistor Box (due to different impedance level).
Can I just get away with just the ecu, distributor, and new 4wire O2 sensor or would it be best to run obd1 injectors as well?
Hope I can get some advices and opinions on this topic!
