Alrighty g2ers, I have a huge favor to ask from you. On an obd1 g2 engine harness, can someone grab the wire colors for the passenger side 14pin, and the two drivers side plugs, I don’t need the y/blk ground that’s blocked off.
I would like to do a write up that will help some people out, but I need this to make sure my pins locations are correct on these 3 plugs.
If possible, something like the below looking at the Back of the plug, Clip side up. Ex. Drivers side 14pin I found through research, and may be wrong
Black/yellow, White/blue, Red
Blue/yellow, Yellow/blue, Yellow/white, Blue
Yellow/red,Green, Black, Yellow/green
Yellow/black,Green/black, Yellow
By doing this, your helping me help the community!! Thanks
I’m not sure if these are helpful or not, but I penned some diagrams/lists of wiring and connectors when I did my engine swap a year or so ago. I had all the wiring for the engine harness apart so did this so I could put it all back together when I was done cleaning and re-wiring the front end.
