you are supposed to jump a plug and your check engine light will flash the code. i don’t know what the plug looks like. i have heard that it is near the passenger kickpanel. maybe someone with an originally obd1 car can give you its location. i have an obd0 to obd1 converted car so i had to make a switch.
The plug is on the passengers side kick panel and had a Brown wire and a Green/White wire.
With the key in position #2, put a piece of wire or paperclip and jump the plug. You will then get flashing from the CEL.
you will get a series of blinks with a pause, then a new series if it is a double digit code. Just count the flashes. For example, if you get 2 flashes a pause and another 2 flashes, your getting code #22.
Here is a list of codes for an obd1 Honda
Code 0 and 11 Electronic Control Module (ECU)
Code1 Heated oxygen sensor A
Code 2 Oxygen content B
Code 3 and 5 Manifold Absolute Pressure (Map Sensor)
Code 4 Crank position sensor
Code 6 Engine coolant temperature
Code 7 Throttle position sensor
Code 8 Top dead center sensor
Code 9 No.1 cylinder position sensor
Code 10 Intake air temperature sensor
Code 12 Exhaust recirculation system
Code 13 Barometric pressure sensor
Code 14 Idle air control valve or bad ECU
Code 15 Ignition output signal
Code 16 Fuel Injector
Code 17 Vehicle speed sensor
Code 19 A/T lock-up control solenoid
Code 20 Electric load detector
Code 21 V-TEC control solenoid
Code 22 V-TEC pressure solenoid
Code 23 Knock sensor
Code 30 A/T FI signal A
Code 30 A/T FI signal B
Code 41 Heated oxygen sensor heater
Code 43 Fuel supply system
Code 45 Fuel supply metering
Code 48 Heated oxygen sensor
Code 61 Front heated oxygen sensor
Code 63 Rear heated oxygen sensor
Code 65 Rear heated oxygen sensor heater
Code 67 Catalytic converter system
Code 70 Automatic transaxle
Code 71 Misfire detected cylinder 1
Code 72 Misfire detected cylinder 2
Code 73 Misfire detected cylinder 3
Code 74 Misfire detected cylinder 4
Code 75 Misfire detected cylinder 5
Code 76 Misfire detected cylinder 6
Code 80 Exhaust recirculation system
Code 86 Coolant temperature
Code 92 Evaporative emission control system
