obd2 into obd1 car
`This is the first one I have done and was wondering what I need to make this swap easy. I have an obd2 b16 with wiring harness and tranny out of a wreck SI and I will be putting it into a 92 gsr. The motor out of the 92 gsr is gone but the wiring harness still remains. I have 2 obd1 ecu’s and a obd1 to obd2 jumper. Is there any thing else that I will need to complete this swap?
holy crap…anyone???
for the motor, re use your obd1 injectors, get a obd1 vtec distributor, reuse your engine harness. And most likely you have to change the post mount on the driver side of the block to bolt onto your existing mounts. For the tranny get the hydro conversion tranny mount and lever. But if your GSR tranny is still good, just put that one onto the b16 and get a new clutch. The ecu, keep it simple, use a obd1 vtec ecu.
thanks man I figured that I will need to use my old harness but it is hacked up and I really don’t want to use it but I will. I need to do some work to it first.
