obd2 ls into my 90 gs
ok so my headgasket is blown and my rings are fried. found a cheap 98 ls for sale. thinking about putting it in, but i don’t know what to do about the wiring. should/would i just use my old intake and exhaust mainfold, distruburtor, and alternator? oh yeah and would i just use my old ecu too?
help please i kinda need to get this thing running before school. thanks any input would help.:up:
yup just use your stock header and §§§§§ and injectors but if i remember right you can use the 98 ls intake maniforld and you should be set.
oh well the only thing is on the back of the 90 block is a water temp sensor and on the obd 1 and 2 they are on the water jacket
hope this helps
thanks
justin
so what do i do about the water temp senor?
just run the wires to the new place on the water neck and plug it in there
hope this helps
justin
