only my fuel and temp gauge works.
how can i trouble shoot the tachometer/odometer?
replace?
What about the lights to they work? I believe the odometer/speedo is a mechanical setup via the speedo cable in the back. Also what led up to this problem?
the lights works.
where in the back? the odo/speed meter or somewhere in the tranny?
i wish i know what cause it but got the car like this.
The speedometer cable is connected to the back of the instrument cluster, [speedometer], it runs from there out through the firewall to the VSS, [vehicle speed sensor] mounted into the transmission.
Your problem may be the VSS, the cable, [broken inner cable] or the speedo itself.94
[QUOTE=fcm;2148097]The speedometer cable is connected to the back of the instrument cluster, [speedometer], it runs from there out through the firewall to the VSS, [vehicle speed sensor] mounted into the transmission.
Your problem may be the VSS, the cable, [broken inner cable] or the speedo itself.94[/QUOTE]
how would i test the VSS and the speedo?
speedo tested OK
cable seems to rotate when you rotate the VSS gear
when i removed the VSS out the trans, the gear inside the trans don’t even rotate, is this normal?
