which one is it that we can use? theres so many different ones that look like the one i always see but im not sure which it is. and when using it, does it just use the same terminals as a regular battery?
680 different mounts an you can not use a regular charger on the battery
http://passwordjdm.com/Odyssey-PC-680-Battery-P1794C322.aspx
so that one… and the regular terminals work on it?
terminals are extra
so it uses its own terminals that are then put on the wires that are connected the regular car terminals?
yep you buy there post it screws in to the battery then your stock battery ter. mount on top just like a reg battery
thanks for clearing that up for me…
it says 680T… is it the same?
that’s the one. the T is probably for the terminals.
how can i tell if its all the correct standards? like cca and voltage and stuff…
well it’s 12V so that’s good and CCA depends. the one you posted is the one everyone buys. i had that battery two years ago but i went back to a normal size relocated behind the passenger seat. not because it was weak or anything but i didn’t put it on a maintenance charge during winter storage and scraped the battery ![]()
