OEM part list, if you have part numbers please read...
I am putting together an OEM part list on an excell spreadsheet…
If you have any OEM part numbers please post them here or email them to me so I can expand my list and in essence help more people out here. I am making a list for all integras from 90-01 so if you have newer teg part numbers just throw those in too.
If you do post up some part numbers please tell me these things…
Part Name
Part Number
What car it was used on (I need this info since some parts are different between the 90-91 and 92-93 tegs)
That should do it.
Thanks in advance.
Later,
BR
br, you should email member leftcorner. if i’m not mistaken, i think he works at a dealership, and he could get a whole bunch of information for you, i’m sure. he’s helpful…
rear trailing arm to lower control arm bushing
52365-SK7-A02
integra 90
rear trailing arm to upper control arm bushing
52395-SR0-A01
integra 90
these 2 parts are collecting dust in my room…
HTH!!
cspeed - If he wants to help out he can, but I am not going to bother him for that much info, unless of course he can get me the honda program with all the parts and diagrams on it. That would be so good to have.
Answer - Thanks for the numbers.
Later,
BR
BR: a guy I know works at the Acura dealer here, I asked him about the program with all the parts numbers… he cannot give it to me because it has all the prices in it…(that’s what he said)
but I you are able to get it, I want a copy!!! :smiley:
Yeah, if I can hook up with that program I can scrap this whole .xls spreadsheet thing and just use that. I do have some hookups at the dealer so I might be able to get it, but that is a long shot.
Later,
BR
valve cover gasket
11251-p30-004
1992 gsr
oil filter (usdm-filtech)
15400-p0h-305
1992 gsr
http://www.acuraautomotiveparts.net/
does that help at all? Or are the part numbers incorrect?
maybe its just a good way to know what everything’s called and where it goes; u could still use the pretty pictures
Originally posted by Redteg
[B]http://www.acuraautomotiveparts.net/
maybe its just a good way to know what everything’s called and where it goes; u could still use the pretty pictures [/B]
That is the dealer diagram, but the part numbers are not the honda/acura numbers.
Later,
BR
Inner valve cover nuts (below spark plug wire cover)
90212-pr3-000
any B-series VTEC engine
Shifter stabilizer bar washer (connects bar to tranny)
54304-sk7-000
2000 Si, but should fit all Tegs
Shifter stbilizer bar bolt (connects bar to tranny)
95701-08018-08
Same as above
If I dig up any more I will be sure to post. Good idea, BR.
Oil Pan Gasket 11251-P30-004
14mm Oil Pan Plug 90009-PY3-0000
whoa, this is an old topic. br, you still doing this spreadsheet? if you like, there are a lot of internal part numbers for the engine over here at www.typerparts.com
33503-sk7-a01
90-93 Tail light Gasket
I was doing my own install for something and the dealer printed me a sheet out of the part I was working on with all the other parts int he area and part numbers at the bottom. It was the drivers door seat belt assembly it had the motor, track and other door pieces. Maybe I can find it. I think prices may have been on it too.
