Oem Piston Replacement???
i am looking on ebay right now and i see brand new oem type-r pistons that have10:6:1 compression i was wondering if these could fit in my car the chart thing next to it says it doesnt but the title says ALL INTEGRAS
94-01 gsR
97-01 Integra TYPE R
94-01 LS
94-01 DC2
i have a 90-LS WILL IT FIT ???
Thanks in Advance:)
First off make sure that the ones you get are for the bore you have. If your cylinders are overbored be sure to get over sized pistons. To make the pistons fit all you have to do is have a machine shop shave a little off each side of the little end of the rods. They can fit the pistons to the rods for you.
sounds expensive and alot of work i dont think my cylinders are overbored i recently bought this car from a surfer who wouldnt know a valve job from a blow job
