Offset questions....?
I have a set of 15x6 fits with a +55 offset what’s the biggest spacer I could run?
How long are your studs? What size tires? Are your fenders rolled? What is your ride height? How stiff are your springs?..
40mm is the stock off set
30mm. That’s the quick answer. You could theoretically add probably another 5 on top of that, but I wouldn’t personally run a spacer on top of another spacer.
I’ll get all the technical info…
But your telling me I could run a 30 mm spacer with the wheels?
