Oil catch can.
How should I run an oil catch can? I have a 92 integra b16a and I’m getting ready to turbo it. I wanted to see some of your guys setup of the oil catch can and what the best way to run one is.
Either delete the freeze-plugs on the back of the block, and put a/n fittings there and run the lines to your catch can…
Or weld A/N fittings into the valve cover and run the lines to your catch can.
Google it, there are ideas everywhere.
edit
or
The options are endless… And it really depends on where you want to mount your catch can.
I mounted mine on the front-driver side, behind the headlight. There is a cut-out in the frame where the AC components go, mine fit perfect down there.
Here’s mine:
Awesome thanks. That will work out pretty good.
What was done with the port where the yellow arrow is pointing too?
