Oil leak
Having an oil coming out of the left corner of the head under the VTEC solenoid.
I just recently change both gaskets on the VTEC solenoid and cam seal and distributor a mouth ago but after that I put in some bigger cams on the engine, my guess is that when I pulled the cam caps I had to replace the cam seal again?
Also if I put my finger where the cam seal is at I pick up some oil on my finger.
Sounds like you have it narrowed down. I’m assuming it’s not coming from that corner of the valve cover?
Could be that also I have to replace the valve cover gaskets
Wipe it clean and let the car idle. See if you can pinpoint where its coming from
http://www.oreillyauto.com/site/c/search/Leak+Detectors+%26+Sealers/N2323/C0014.oap?categoryRedirect=N2323
clean it, add some dye and check after you notice it.
