[size=3]my 92 da9 oil light will turn on and off . It will often flash on and off quickly. I check the oil every morning after i notice the flashing and oil checks out to be at the correct level. So i am guessing it has to do with the wiring or something .plz help!!! [/size]
Some one correct me if I am wrong, but that is due to oil pump failure. You have enough oil but there isnt enough pressure.
[QUOTE=386;2301958]Some one correct me if I am wrong, but that is due to oil pump failure. You have enough oil but there isnt enough pressure.[/QUOTE
Or the pickup screen is clogged.
or the sensor is bad
Thanks for all the help I hope it will be the sensor because the other to can only be bad news . ![]()
check ur ecm its behind the fuse box on.driver side kick.panel mine.sid that shit and beeped it was the ecm it was burnt out
that is not the ECM, it is called an ICU… It controls all the interior systems function & the oil lamp. may be your culprit for the whacky oil light also, but if I were the OP I would check oil pressure with a mechanical gauge and rule out any mechanical issues by checking the oil pressure.
Also I highly suggest you go and get an OEM oil pressure sender from Honda or Acura… those cheap ones on ebay and @ parts stores DO NOT THREAD CORRECTLY.
