So I was replacing my oil pressure sensor and the the place where you mount the sensor broke off. So now. I have no way to stop the oil from leaking out. Is there any solutions to block it off? Will JBWeld work on it?
Did you damage the actual threads on the block?
if so you can always tap or re thread the hole one size bigger and find fittings that will fit.
Take a pic.u
No, the place where you mount it took off. Well half. When I get home later I’ll post up a picture to get a better idea.
Did that on my first b16, was from over tightening it. JB weld didn;t work for shit, had to pull the motor and get it welded shut. Oil has to be drained first too .
Did you just bring it to any shop that does welding? How much did they charge you?
Here are some photos of what happened so you guys get a better idea.
That is not soming you are going to be able to repair in the car. I am not sure that it even can be repaired.
