Ok so I have been searching for a while now and I know this is a 90-91 bumper like mine but the lip is definently stock looking but a bit more aggressive then my stock 90 lip…
It’s db1st’s car from this thread. I see him post here a lot but I can figure out how to contact him
yes it is a 1st gen '89 integra lip and there is very little modification needed, it’s possibly one of the most used OEM lip on our DAs. all the bolt holes mounts up to the 90-91 front bumper as well. below is a copied post i did a few years back on how to mount the front lip CORRECTLY…
[QUOTE=db1st;1970768]hahaha38…i have 89 integra front lip on my 91 integra…it is pretty accessible, you can basically find it at any junkyard (i got mines for about $6 at pick-n-pull). all the bolt holes from the 89 front lip matches up so there won’t be many modifications on the bumper or the lip other than you having to trim down both ends on the lip so it matches your bumper. if you’re thinking of doing this for your car, i suggest for the best results you use longer bolts(2½ in.), washers, and plenty of nuts(i used about 30-35nuts, no joke!!!) or spacers to make it easier, but i dunno the lengths needed(my guess would be ½ in. spacers) to help adjust the lip for proper fitting and to lock everything down.
here is the lip on my car just bolted up w/ the original bolts…as you can see it sits too far up and there are gaps at both corners of the bumper
…and here you see this is how it looks like after spending more time on installing it using extended bolts and all those nuts!!!
im not sure if this is what you’re looking for but…hopefully this helps a little. in my opinion, it doesn’t look too bad, almost like the JDP lip…ALMOST!!!.[/QUOTE]
really? can you have one shipped to me? i dont have an acura dealer where im at, only honda. can a honda dealership get it? if so, you you please provide the part number?
