Ok, I'm pretty sure its my Main Fuel Relay...
For those that haven’t read the other post, when I try to start my car, it will start and run like normal, but only for about 2 seconds and then it slowly dies. Well, its doing it almost every time now, so I’ve had the chance to narrow down the problem.
The first time I start the car, I can hear a relay click on, then off and the car starts. When I try to start it the second, third and fourth time, there is no sound of a relay clicking. I’ve put my hand on the relay that I hear, and through that method have figured out thats the relay that is clicking. Its the clicking that you hear when your Check Engine Light comes on, then turns off after 3 seconds when you turn the car on, but don’t start it.
I’m pretty sure this relay is my Main Fuel Relay. But before I go out and lay down the cash for another one, I just want to make sure there isn’t something else I’m not thinking about.
And the only way I can start my car now is to start her, then rev her up to around 4,000 rpms and keep her there for a few seconds. I can still hear her try to die, but because the revs are up, she comes back to life after only about 500 rpms of dieing. Then she runs fine.
-Steve
shoot me an e-mail…i have one i’ll sell you pretty cheap…
Too bad you can’t borrow one for a week or so to make sure. Good luck Steve.
Thanks, but I just orded a new one from ahmotor.com. It should be here tommorrow and I’ll know then.
-Steve
all you have to do to fix a main fuel relay is to re-solder every (about 6) connections inside of it and you’ll be good for another 10 years!
'takes about 10 minutes to remove and open, 5min to re-solder and 10 minutes to re-install :slight_smile:
it’s useless to buy a new one!:wink:
