Ok: shift linkage
I need a shift linkage I hope that will fix it so if anyone is out there has a spare shift linkage laying around ill buy it off you
Pretty sure I have one laying around if you need it. What’s wrong with your current linkage?
I’m having trouble getting into second gear its not grinding or anything its like hitting a wall and then it gets into gear my transmissions about a year old from syncrotech I called them and told them what was wrong and they didn’t know what was wrong with it so I bought new shifter bushings and I want to put a new engine before I pull the transmission and send it to them do you have any ideas any help would really be appreciated
when I said engine I meant to say a linkage its my dumb predictive text its like its locking me out of second
That sounds a lot more like bad syncros than shift linkage. Second gear is the only problem gear? I’ll take a look around for that linkage today if you’d like but I’m not sure I think that would help you out. I guess its worth a shot though. Did they ask you to try that first?
