old struts???
can haveing worn out back struts cause camber probs??? my teg isnt lowered and the camber is off, anything you guys can tell me would be appreciated:)
Worn out struts in the rear will not give you camber problems. The only things that would affect rear camber is worn out bushings or a seriously bad hub bearing. Check the rear upper arm for bending or other damage.
