One high beam doesn't work but everything else does
So I have this weird problem with my daily. One of the high beams don’t work (right side), but everything else works, and I can guarantee you the bulb is 100% fine as it runs perfectly in my other teggy.
What do you guys think the problem is?
how can you guarantee it? the only way to know for sure is switch you’re right side bulb with you’re left side bulb… if the problem continues on the left side the its obviously you’'re light bulb… if the problem continuse on the right even though it has a different bulb we can narrow the problem to wireing… keep us posted!
I can guarantee you the bulb is 100% fine as it runs perfectly in my other teggy. [/COLOR] I assume that means you tried the bulb and it works.
First thing to do is test for power at the right side high beam fuse, [hot when high beams are on].
If there is power at the fuse I would check for power at the right side high beam bulb socket, also test for ground at the socket.
Where in BC are you Cillu? 94
I can guarantee it because I’ve tested the bulb on my other teggy and it works just fine. Must be the connection somehow then.
[QUOTE=fcm;2192173]I can guarantee you the bulb is 100% fine as it runs perfectly in my other teggy. [/COLOR] I assume that means you tried the bulb and it works.
Where in BC are you Cillu? 94[/QUOTE]
Alright, I’ll check later tonight. Thanks for the tips!
I’m located in Vancouver near Metrotown.
hope it works out… keep us posted on how u solved the problem… so someone can later do the same. thanks
