Okay, it seems that other than lowering our cars, the most common upgrade I’ve seen are the one piece headlights.
Now I’ve seen the teg tips on “renewing” them or discussions about the average cost but I haven’t seen anything that talks about installing them. Is it because it’s SO easy it wasn’t worth the time to put it in teg tips (& I’m the idiot for asking) or has no one just had a chance to put it in there.
See, IF I do get them, I want to know I can install them myself without too much of a headache.
its pretty much self explanitory. Remove the bumper, take the screw out of the lights … match the wires to the JDM headlights, screw them in, Adjust them, put the bumper back on. Done.
There was a guy that was gonna write one up, but I haven’t seen anything.
Its simple bro…when u get them…just pop the hood, theres 3 bolts on top u can see in plain daylight and one under the headlight assembly. To easily reach this bolt, u can take the front bumper off and reassembly is the complete reverse…it helps to buy a Helms Manual if u plan to do work on ur own car…it’ll tell u where every friggin bolt and screw goes…
but yeah, Im guessing theres no teg tip for it cause noone has the time to write it up or take pics of the process or all u would see is a couple sentences like a wrote above…really easy! Have fun.
Originally posted by asian buddha
[B]Its simple bro…when u get them…just pop the hood, theres 3 bolts on top u can see in plain daylight and one under the headlight assembly. To easily reach this bolt, u can take the front bumper off and reassembly is the complete reverse…it helps to buy a Helms Manual if u plan to do work on ur own car…it’ll tell u where every friggin bolt and screw goes…
but yeah, Im guessing theres no teg tip for it cause noone has the time to write it up or take pics of the process or all u would see is a couple sentences like a wrote above…really easy! Have fun. [/B]
maybe around 25-30 minutes at most. The bumper is so easy to take off you wouldn’t belive… Two bolts in the fenders, two behind each signal, 3 underneath and bam shes off. The the light just splice into the stock harness and bolt right up with the brackets. very easy… good luck!
