can someone who has bought the one piece projector headlights help tell me which wires to hook up to what, since the projectors have a seperate high and low beam harness??? im not too sure if its the same as hooking it up like the regular JDM one pieces…the company i bought it from didnt give me any instructions on how to install it…
so can sumone help…pics/diagrams would be nice=) please…`!!!TIA
I have the projectors, there are no mods needed if you still have ur usdm harnesses… if u cut them off for say, a jdm conversion, I dont konw what to tell you, the only thing that doesnt fit with the projectors is the foglight harness, with that its only two wires, red and black, splice, twist and cap and ur done… hardest part about the whole thing is gettin the lights aligned, …email me at kzgco04@aol.com with any more questions
thanks…also…do you use the philips screw driver to aling the lights???i see that there are 3 screws on each one piece and i figure they are for the alignment…but i dunt wanna break nuttin…so is that how you align the lights???by turning those screws???..please help me…i dont wanna mess these things up…cuz they look so nice=)
if the proj are already installed…how do i change the fog lights??? cuz i wanna make them yellow! do i needa take off my whole front bumper again to get to it?? or is there an easier way??
as far as I know the only way to get to the fogs is by takin the bumper off because they are behind the radiator if I remember correctly
and about the alignment, yes you use a phillips to align them, with those lil wheel lookin things they arent actual screws, dont turn the screws… lol if u understand…
Need help installing my Halo Projector Headlights, they look nothing like the stock ones for wireing, need help! searched and didnt get what I was looking for. Where do the black and red wires go and what is the big blue thing for ?
um, alright i know i found the info i needed on here on this site when i put my projectors (halos) in but anyways:
- black & red wires splice them into your corner lights (aka parking lights).
black is obviously ground and red the 12v. (these are what power the halos) - the “blue thing” should plug into your headlight harness.
now i know when i got my projectors the plug from the car didnt fit into the plug from the headlight for the fog lights. so i went to the junkyard to cut off the (female foglight plug i believe) plug and spliced them onto the headlight. so it plugs in like stock.
it would also be a good idea to use some sort of connectors for the halos when you splice them into your parking lights. this way whenever you need to remove the headlight for whatever reason you can just unplug everything without having to cut anything.
lmk if you need anymore help.
HTH.
edit: oh yeah a couple more things before you ask:
the lightbulbs in these things are (i beleive) h3 for the headlights and h1 for the fogs. it’s a pain in the ass to change them since you would need to take off your bumper everytime.
and yes the projectors light up less than other headlights, but if you either remove or shove the glare guards out of the way then they will light up ok.
and yes most of the info i wrote above i found by searching on this site, even this thread tells you how. good luck.
wow, this thread dates back 3 years! lol:sipread:
it shows how much of a noob i used to be! LOL
yup. i was thinking the same thing. lol.
