One-Piece pursuers!
I found one of these plugs at work, so i figured i would post this info. This is the pigtail you will need when you get one piece headlights. Also can be obtained from a 1992-1995 civic. Hope this helps people!
http://www.xtremeinc.ca/product.php?productid=16704
The information for what wire you would tap into are available on this site.
If someone knows it off hand, please reply!
password jdm has 2 options to wire up jdm one pieces
easy plug n play type password jdm headlight jumper harness or solder/butt connect type password jdm h4h headlight harness
I also noticed on my old 91 toyota 4runner had the same plugs that where used on the 1 piece headlight, one day when I actually have a set of 1 pieces, ill pick up a set to see if they actualy fit
I thought that everyone who didn’t have a gaydm password harness used 92-95 civic plugs. The integra harness is red/yellow stripe, red/blue strip and a solid black wire.
red/yellow stripe - red/white stripe h4 plug
red/blue stripe - red/black stripe h4 plug
black - black
Hope that helps. Bold is integra harness colors, red is the h4 harness colors
H4 (sold in the US) & H4H (jdm) bulbs use the same exact connector…
so you can even get it at an auto parts store.
