hey guys i was just wondering if i can put xenons in my one pieces or would it b to hot for the plastic lenz???
meeee toooo… but i believe itll end up warping n melting plastic so oh well =[
Um if your talking about Xenons as in HIDs, they run at 35 watts normally (although there are 55 watt kits), which is lower than halogen stock wattages.
There should be no issues with heat.
o sick i guess ill try it out then i only paid 75 bucks for my one pieces anywayz soo its not too much of a loss
I’ve got a HID kit in my 1 pieces. No problems.
Only problem that you will run is that if you don’t retrofit the headlights with HID projectors. The lights will just scatter all over the place along with blinding drivers, below is a picture of my car with retrofitted with projectors. Notice even with the projectors it’s still not 100% perfect because of the flutes in the headlight.
what projectors are those?
They are 7 series BMW projectors.
oh i see. is the cut off and output pretty good? are they single or dual beam?
