are both of the fans supposed to run when the car is idleing??? or is the smaller one just for a/c. i just put in a new radiator and i had to tug on the wires kinda hard to get the smaller fan out. im thinking maybe i pulled the wire a little to hard and now the fan isnt getting power. i thought both of them ran at all times. can someone please clear this up?
nope they dont run all the time. the passenger side is the a/c fan. i think u should know when it comes on. when u turn on the a/c. the other fan comes on when ur engine gets warmed up and its getting hot. i only know when its idle. not sure if it runs all the time when the car is moving.
are u sure the one on the pass. side is the a/c fan cuz that is the only one that is cycling on and off once the engine is warm. and it is coming on when the a/c isnt on
driver side is A/C fan… pass. side is the cooling fan…
so is the a/c fan only supposed to come on when the a/c is on??? cuz i swear ive seen that thing runnin without the a/c on. maybe im just talkin out off my a$$
does the a/c fan only run when the a/c is on???..
The A/C fan can be activated by the oil temp switch also… cause my cooling fan relay was toasted and the A/C fan was running when the temp was too high… My car never overheated even though my cooling fan relay was bad(unless I used the A/C).
