In my g2 both of my headlights work fine until I turn on my full beams, then only one headlight works…
I have replaced the bulbs but i’m still having the same problem?
Does anybody know whats going on? I knew of another person who had the same problem but dont know whether they found out what was rong with it…
Check your fuse for the passenger side high beam
What if the problem is the drivers side high beam?:hmm:
glencox He is correct, check the fuses, or fuse for the side that is not working, left high beam is fuse 10 - 10A, right high beam is fuse 9 - 10A in under dash fuse box.
Unless you have a multimeter, [or at least a test light] you need to go and buy one to do any other testing of the electrical system of your car.
BTW, replace the fuse even if it looks good.:whisper:94
