ok what i have in mind is built b18A1 running in the 20 psi range with cams, P&P, stock to 10:1 compression ratio (great tune will be needed i know)
im going wiseco pistons, eagle rods, cometic head gasket, and ARP fasteners the ones im curious about is what would the b18 guru’s recommend for bearing set, thrust washer, overhaul gasket set, etc.
and really any other recommendations with who/where to buy parts through
Scrap the acl idea use oem bearings. If u look em up ull see that they are color coded for install designed to work at it’s best possible way in ur lower end.
