OR: 92 Integra GS Part Out
I can do $125 shipped. Send PayPal to g2guru@comcast.net. If I get it tonight, I can ship as early as tomorrow.
I’ll check on some quotes for shipping tomorrow. I’m guessing it may be around $75. But I’m not positive. This roof is in great condition.
Payment sent, thank you!
Payment received. Shipping tomorrow.
alright let me know man. is it obo or you got a price your trying to get for that?
It’s best offer.
Parts Still Available:
B18A Engine and Manual Transmission. 175,000 miles but ran and shifted great. SOLD!
Koni Yellow Adjustable shocks with Ground Control Coilovers and Ground Control Exteneded Top Hats-All four corners (less than 10,000 miles)
-Spring Rates: Front- GC200.64.58 (8"L/ 2.5"Ø /340 lbs); Rear- 0800.250.0250 (8"L/ 2.5"Ø /250 lbs) " $725 - May be willing to separate
ASR Subframe Brace (Red Anodized) with ASR 24mm Swaybar and Heim Joint end links. $280
ST Front 24mm Sway Bar. Perfect combo with the ASR 24mm. SOLD!
Black Door Panels with black pleather inserts (red stitching). One door panel is damaged near the speaker (F’ING THIEVES!!!) but easily repairable. $100
Black Rear Panels with black pleather inserts (red Stitching). Matches front Door Panels $100
Skunk 2 Front and Rear Camber Kit (less than 10 months old) $250 FIRM - May be willing to separate
B&M Spherical Bushing Short Shifter (car was stolen shortly after install, basically new)$75
Cluster with custom red LED back lighting and red needles (did this conversion myself) $100
Climate control with custom red LED back lighting $40
Dash trim panel with custom red back lit cruise control buttons perfect for aftermarket wheels still wanting the use of cruise control $40
Front Steering Knuckles with new bearings and ARP extended wheel studs installed. $75
Rear Trailing Arms with new Honda bushings and compensator arms, new bearings and ARP extened wheel studs installed. $75
Eibach Pro 5MM (4x100) Wheel Spacers SOLD!
90-91 Taillights “de-pinked” SOLD!
Complete OEM 3 piece headlight assemblies (come with PIAA bulbs in both fog light and headlight) $75
HASport B-Series Axles SOLD!
Non-LED Hatch Spoiler (Black) $50
Power Hatchback Mirrors (Black)- good conidtion structurally and mechanically, but need repainting $50
Front Crossmember with Radius Rods (unmodified/good condition) $75
Moonroof assembly (great condition-no rust) $100
Clutch Cable $25
Throttle Cable $15
Speedometer Cable $15
New Fuel Main Relay $25
Power Antenna Assembly $20
Rear Wiper Motor Assembly $25
Miscellaneous interior panels
alright gimme two weeks for that moonroof and my leaks will be solved. haha i just did my oil and spark plug wires which were ngks so a bit pricey and i had a couple other things to take care of. but if you got it in two weeks still im buying it for sure man
I doubt it will move until then. Still getting quotes for shipping.
alright. thanks man
Free bump for Nice parts. $175 shipped for the front upper control arms?
May have a local guy interested in both front and rear. Should hear from him by Sunday. If they don’t sell, I may be willing to drop the price a bit to get you $175 shipped.
hey dan how much for the a/c harness in the engine bay?
Sorry, the car was towed off last week and I didn’t remove the AC harness.
I’m surprised there hasn’t been more interest in the ITR Shift linkage. Perhaps people just don’t understand how necessary of a mod this is. The stock shifting in the DA feels “Flimsy” and sloppy. The larger diameter shift change rod of the ITR linkage changes all of that. Shifts become quite solid and accurate. For those that have done this mod, myself included, this is one of the best bang for your buck drivetrain mods. You can find the shifters online between $175 and $250. But sometimes the hinge pin at the front joint (near the bitch pin) will be really sloppy from people not knowing how to install or from rust. This linkage is very tight. It’s in great condition. The shifter is also very nice and solid. For $250 for the pair with ES bushings I think it’s a steal.
Hey dan how much shipped for the asr brace and sway bar to 89148
$315. If shipping is more I will cover it.
Nice and how much for a package deal say if I took the type r shift linkage and st sway bar too
So do you want the shift linkage and shifter, or just the linkage?
Just the linkage
