I’ll tell you what. You buy all three ($600), I’ll cover shipping which I’m guessing will be between $50 and $75.
Thanks dan but I found out my wife just bought me that asr for my birthday lol I’ll take just the linkage how much and what’s your paypal?
You still interested in the ST Front Swaybar? I will do $300 shipped on the linkage and the swaybar. If you just want the linkage, it’s $190 shipped. Paypal is G2guru@comcast.net. Please send as a gift to avoid fees. You know I can be trusted
Hey dan just sent payment I’ll just take the linkage thanks!
Payment received. It will go out Monday. Thanks.
Bump
B&M Short Shifter with Spherical bushing. Like new! $100 obo
Interested in the rear trailing arms shipped to 11366.
Do you have a pic of the bushings from the wheel well?
Edit* Thats it in post #112 right?
If the power antennae goes all the way down, im interested in that too.
rear speaker covers are gone?
Thnx
[QUOTE=saigonsson;2316319]Interested in the rear trailing arms shipped to 11366.
Thnx[/QUOTE]
Brand new genuine Honda Compensator Arms.
Brand new genuine Honda trailing arm bushings (installed properly to minimize twist on a car lowered 2").
The flaking you see in the above pictures is not cracking. It is a top coat Honda puts on the bushings and is completely normal. These bushing are less than 3 months old. I had just installed them along with the compensator arms. Shipping on the arms would probably be about $50 due to the size and weight. But if you want them, I could ship.
The power antenna is all the way down now. I will power it up and see if I can get it to extend and retract. It was working before the thieves took the car. But I’m not confident they didn’t screw it up.
I have all four speaker covers. To which are you referring? The fronts I would rather sell with the door panels, and the rears are perfect other than having a flush LED drilled into each for an alarm system.
How hard would it be to pull those trailing bushings out? Yeah check on the Antanae.
Maybe the trailing arms fit in a fedex flat rate box?
U still got headlights , blinkers and bumper light wirings and also sockets ?
[QUOTE=saigonsson;2316425]How hard would it be to pull those trailing bushings out? Yeah check on the Antanae.
Maybe the trailing arms fit in a fedex flat rate box?[/QUOTE]
I’m not going to pull the bushings. While not hard, seems like it would make the rest of the arm worthless. I’ll check on cheaper methods of shipping and the antenna this weekend
I have all of it other than the chassis pigtails. In other words in you have an existing car with wiring, this is all plug and play. Headlights and fogs have PIAA bulbs.
You have any of these not broken? Shipping to 65336?
Need #23 - L FR Slider Assy for door glass and #28 - PROTECTOR, L. DOOR CYLINDER.
Mine are broken and it’s causing my window to rattle and leak wind/air in.
Also need #4 - L FR upper weather stripping
Mine is permanently flat in one spot which is also another spot it’s leaking air into.
[QUOTE=Silverstreek;2316462]You have any of these not broken? Shipping to 65336?
Mine is permanently flat in one spot which is also another spot it’s leaking air into.[/QUOTE]
Sorry, don’t have either of those items as the chassis was towed off and I didn’t remove them.
Thanks dan just received the linkage today! Left feedback!
Excellent! Thank you for letting me know. Hope you are happy with it.
How much for the rear trailing arms and front knuckles shipped to 11372 if I buy together. they all have the ARP studs correct? Also emailed you about the LED conversion you do.
Do you still have the Front ST Sway bar? As well as the GC/Koni set up?
Yes I do.
