USDM B20Z cylinder head (P75-1). Great condition and cams included. Has less than 30,000 miles on it. $100 obo.
B20 Valve Cover $50 obo.
Used AutoMeter Sport Comp 0-100psi Mechanical Oil Pressure Gauge (ATM-3421) $20 obo. Modified to fit with pillar gauge pod (threaded studs cut). New oil line included
Complete JDM 90xsi Instrument cluster. Tach reads to 9500rpm (will provide either JDM or USDM speedometer currently assembled with USDM speedo w/ 124,597 miles - your choice of km or mph as primary units) $75 obo.
NIB MSD 90-93 Integra distributor cap $15 obo.
Used B-Series VTEC Valve Cover (Black Crinkle coat). In great condition, almost new. $80 obo.
Used 92-00 Integra/Civic B-Series Cusco Clutch. Less than 30,000 miles, lots of life left. Removed properly so no pressure plate warping. $100 obo.
90-93 Integra ABS and Master Cylinder Reservoir Cover Caps (Polished Aluminum) SOLD
Used Momo Race Air Leather shift knob (Theaded style with shift gate pattern on top) SOLD
Street Wires Zero Noise 5 Meter RCA Cables $20 Each obo. BNIP
Pictures recently added and all prices are negotiable within reason.
Would there be any performance gains from using that head on a b18a1 bottom end? Also will everything from the a1 head bolt up and work with that head? Intake and exhaust manifolds, distributor, etc.
Thanks!
Really no difference between the P75 and PR4 heads other than year of manufacturing. Intake manifold, exhaust manifold, and distributor will bolt up fine. I’m not sure if the cams are better from a B20, but I’m essentially throwing those in for free as well as the factory cam gears, bolts, and woodruff keys. Really this is a great option if you have a high mileage, tired cylinder head and want a fairly new great condition cylinder head. As you can see from the pictures, the head is in amazing condition and has around 30,000 miles on it. I would sell the B20 head complete with B20 valve cover for $200 shipped anywhere other than Alaska or Hawaii (shipping would be a bit more).
Thanks for the reply! An LS valve cover will fit that head correctly right? Do you have any pictures of the B20 valve cover? If I decided to skip the valve cover and just get the head would you do $150 shipped? I’m very tempted to pic this up and get my other DA back on the road.
