Ok so i got a new door but everything on it is auto so im swapping shit lil by lil now its turn for the miror…the auto easy to take out…3 screws, the manual has the handle from the inside…and now how the fuck do i take that out cuz the handle wont come out through the whole and there is no way im going to take apart the inside of the miror to somehow get the handle off cuz there is no room to work…is there any trick for it cuz i would hate if i have to cut the bitch and the somehow get it back together lol…somebody help please??
nvr had the manual side view mirrors for our rides… but doesn’t it just slide on thru after u remove the 3 bolts? if the end of the handle doesn’t go thru due to a smaller hole, i’d assume that the end was either screwed… or glued, most likely threaded on there tho. check it out carefully.
…i looked but couldnt find it…anybody???
On the handle where you grab to adjust the mirror, is a cap. Pop off the cap and there is a screw. Remove the screw to pull off the handle, then remove the three screws holding the mirror on. There you have it.
Parker
damn never thought about it…ill try when i get home…if ur right then ur the shit cuz i was messing with it today before work and i was about to cut it but i waited to see if anybody has any ideas…I LOVE THIS FORUM!!! so maybe u know how hard would be to make the door with auto windows into manual…do i just swap everything…or can i just swap the motors…is it possible…
