Overheat with a/c on
My teg was about 2/3 up the temp gauge with my a/c on today. i dont normally run the a/c but i noticed it go back down to normal when i turned a/c off. do i need coolant? tia
Check to make sure BOTH fans are running when you turn on the A/C. I had this problem and it turned out to be my cooling fan relay tnat was bad…
