maybe someone can help
i just replaced the headgasket on my 90 integra ls…all stock motor. in the process i got a bolt stuck in the thermostat housing. the only way i could remove it was by completely removing the waterneck. so once i got everything back together i fill the coolant up and i notice that it was leaking from behind the motor. where the tube that leads to the waterneck meets the block (i.e. right behind the waterpump. is this replaceable? or is it possible that i just need to fit that sucker more tightly in there?
pretty sure u can get that at acura or at the junk yard!!if your talking bout that big back tude that runs the back of he block from side to side…im pretty sure thats chageable…someone correct me if im wrong.
No need to post same question in two places. I have answered you in ur other post and lets keep it at that. beside try not to add on to other peoples thread if it has not been answered just incase, but it is changeable this is why he removed it and now he probably didnt snug it in all the way or it is in all the way but just not enough pressure to keep it seal.
sorry about that…just wanted to make sure to get a good answer…all the info helps…and it is very appreciated.
does your steering wheel have cruise control on it?
