p/s pullies interchangable? b18a to b18c
can I put a b18a power steering pully onto a vtec b18c power steering pump?
reason is: i have a b18a p/s aem underdrive pully, i was wondering if I could use it on my type-r motor.
To answer your question, yes the pulley’s are interchangeable. But you’ll create more work for yourself if you want to use the B18C P/S pump. You’ll need to get the B18C pump bracket and figure a way to get the press. hose to line up.
i’m going to have the b18c p/s pump on the jdm itr b18c motor though… it’s just i’m swapping the b18a out and putting the b18c in, and i want to use the underdrive pully off of the b18a pump. or should I just use the b18a pump?
