p61 ecu
Does anybody know where I might be able to download or get a copy of a stock p61 basemap bin file?
Thanks,
1.7na
IS Thier a difference between b16 and b17 maps???
Any which may be more potent?
let us know if you find it but I’m sure it basically a p30 map…I have heard its a somewhat conservative too
I did manage to find a copy on pgmfi.org but not sure if it was a modify version or stock. I took a look at it with chrome and some of the parameters looks to be changed. I would think the b16 maps are the same but I was hoping I can find the original map for the p61.
uberdata should have some maps, I got my p72 one from them
the ones that i’ve found don’t work very well. a p30 base is fine. that’s what i used to tune mine.
Thanks guys. IcemanGSR, did you find the base p30 on pgmfi.org? I have a copy of a p30 base MT from there but want to make sure it’s really a stock map.
BTW, reason why I want a actual stock map is for future smog purpose. I’m in CA and always getting hit with “test only”. I’m currently passing with my current “street” program setup but would like to get the numbers down a little more. Thanks again!
1.7na
it already come w/ crome…if thats what your running?
BGW,
Thanks! Your right, it’s there.
1.7na
I was about to say you should already have it if you dled crome. let us know how it works out.
