i picked up some typer pistons on gsr rods the other day. i want to build a basic bottom end out of a b18a block i have to slap on my lsv . i was also thinking about buying a typer crank from this guy in the next town over. will all this work? i tried searching for like 20 min and it wouldnt run any searches for me. im kinda new to this honda thing as far as mapping out bottom ends.
What motor do you have in your car right now?
The potential combination of using OEM Honda parts for your build is amazing, which will generate a slue of opinions.
i have a b18b bottom end with a pr3 head, itr cams, ctr valvetrain, skunk2 cam gears, venom fuel rail , b&m fpr, 7.5 lb fidanza, with an act stage 4. for my build currently i have a b18a, and p73’s on p72’s. all the local machine shops are scared to take them off the rods b/c they dont want to mess up the pistons. i can also buy a itr crank for 250. which by the way how can i tell it apart from any other b series crank so i know hes not ripping me off? also all said and done i also have a vafc and msd sci for it. but i dont want to do anything else untill i build this bottom end.
so yeah, i have a b18a, and type r pistons stock bore on gsr rods and im gonna buy a type r crank. what has to be done. please guys everytime i go to search the page never loads results.
if im not mistaken that would be a bad idea to put the type r crank into ur b18a block seein how the b18a crank has a longer stroke then the type r crank…
