i was driving today and i heard a click noise in the front were the mph and rmp gauges are and all my interio lights wen off and also my rear tail light wen off…i was wondering what could it be…i was thinking off a burn fuse but im not sure any help out here please…:pupeyes:
might wanna double check all fuses if you havent
yup u heard a fuse blow.
thanks homies!!
yea it was a blow fuse thank very much for ur help…:rockon:
yea there is a fuse for all the interior lights and its wired to your tailights so when that goes out you know because your interior lights dont work.
i have an opposite problem, when i shut my car off my climate control lights stay on :shrug:
with lights switched off obvisouly
[QUOTE=jlak;1854890]i have an opposite problem, when i shut my car off my climate control lights stay on :shrug:
with lights switched off obvisouly[/QUOTE]
u most likely have some jacked up wiring. it must be hooked up to a fuse or connector that has power at all times.
sounds plausible, i usually just press it enough to turn the lights off, but sometimes i forget and it hasn’t drained the battery enough to the point where the car wouldn’t start. but i just don’t like the idea of them being on all the time.
