May I know what wire/color/location is the switch for parking lights in the steering column? Its when you turn the knob up for parking lights behind the steering wheel. I’ve been looking around for wiring info’s, but couldn’t find anything what wire that connects to on/off for parking lights.
Red/Green is for parking lamps (lights in number 1 position)
Thanks man, been searching the info for four hours! haha.
so I went under the dash and found 3 red and green. 1 thick and 2 thin wires. I cut all three, put the parking lights on #1 and its still on. Can anyone show me where exactly the wire under the dash or is there a sperate wire that turns on the Parking light.
You did not find the correct red/green, it is found in the steering wheel harness, park lights are red/green head lights are red/yellow and high beams and flash to pass is red/blue.
What is it you are wanting to do? 94
ok ill try to look at it tomorrow or on alldata. reason is private.
It’s the mother thick one IIRC…i tapped into mine in the steering column, you need to take off all the covers, you can probably also find it under the dash too
Is that where the blue harness is at?
