part number to the push screws
so in teg tips the passanger wet floor fix anyone know the part number to the push screws that you take out? i striped a few
anyone know?
If you are referring to the plastic push screws, these should be it. Hope this helps.
91550-SH3-003ZT CLIP, RR. PANEL LINING
List is 0.43 each.
if you are thinking about what i think you are, they are called Scrivettes
Just a FYI for those who don’t know, a lot of those plastic tabs, plastic screws and plastic rivet screw thingies can be found in auto part stores so you don’t have to special order them. I was looking through autozone a few weeks ago and saw them on the same aisle as the replacement interior clips, grommets and stuff like that.
It might be worth checking out if you don’t feel like going through the process of special ordering and waiting days for it.
[QUOTE=EX PLCIT;1877285]Just a FYI for those who don’t know, a lot of those plastic tabs, plastic screws and plastic rivet screw thingies can be found in auto part stores so you don’t have to special order them. I was looking through autozone a few weeks ago and saw them on the same aisle as the replacement interior clips, grommets and stuff like that.
It might be worth checking out if you don’t feel like going through the process of special ordering and waiting days for it.[/QUOTE]
good one…
i always take some from the junkyards if i get some other part… i say its included with the part if they say some thing
[QUOTE=doozyj;1871611]If you are referring to the plastic push screws, these should be it. Hope this helps.
List is 0.43 each.[/QUOTE]
I have an extra one in front of me and it’s not that #. Mine is 90657-SA6-003. That’s the one you want. They’re 1 or 2 bucks a piece. I forget
is there a way to remove them without actually destroying them, or do I need to just stock up?
If you can get a flat blade or something under the base to pull up on, it usually gives the threads better contact but it’s no guarentee. Some of them are hard to get under. I got 4 or 5 out ok, but the rest were a pain and I just ripped them out. I’d have at least 3 or 4 extra.
