pass side power window
alright this is for clarification that its the wiring…so my window motor went out and i believe the switch did too because only the master switch would ALWAYS roll the passenger side window down. but the passenger switch worked intermittently. so i bought a used switch (from a 2 door which is what my car is) and a window motor and regulator. i made sure that the motor worked by directly jumping it from the battery…i also tested my old one and it didnt work. so i hooked everything back up with the old switch and new motor. didnt work.
ordered a switch but it all back together…still didnt work no noise or nothing. i checked the fuses not the relay yet but i feel that if it was the relay none of the windows would work…but im unsure. the switch could be bad again since its used and i know how to clean the contact points but last time i did that with my old switch i pretty much broke it to do so. so now i dont want to take the switch apart for fear of it breaking and 30 bucks being wasted…i rather no if its my wiring or not beforehand. so any suggestions as to what else it could be and how i should go about diagnosing this problem? thanks my friends
nevermind delete
